FE-35
Chris
09-01-2001 06:19:03
I have 2 Massey Ferguson FE-35's. They are both diesel. The serial #s on the cowling are SDM 85303 & SDM 123341. They both have the Standard Deisel engines, but one has glow plugs, (doesn't run) and the other one doesn't. I was wondering if anyone could tell me the years of these tractors. Is there any difference in the models that makes one a deluxe or something? Also, I need the front sheet metal for the second one. The metal that came with it is pretty poor. The first one runs great and is used regularly. Thanks for any help.
C. T. in Oklahoma
09-01-2001 14:35:26
 Re: FE-35 in reply to Chris, 09-01-2001 06:19:03
I forgot to mention, Deluxe means you have "Dual Clutch", and "Tractormeter" for hours and RPM, and High/low range transmission for a net of six speeds forward and two reverse. I believe there are a couple more things, but they escape me at the moment. Maybe somebody else will give a better definition. By the way, dual clutch means "clutch half way depressed stops movement of tractor, but PTO still turning, clutch fully depressed stops movement of tractor and stops PTO". C. T.
C. T. in Oklahoma
09-01-2001 14:23:18
I found this on www.fofh.u-net.com/dates.htm.
Serial Numbers and Year of Manufacture (Total built: 387,381). 1001-9225 1956 9225-79552 1957 79553-125067 1958 125068-171470 1959 171471-220613 1960 220614-267527 1961 267528-307230 1962 307231-352254 1963 352255-388382 1964 Looks like both of yours were built in 1958.
