200 dozer transmission oil
kene senske
09-22-2001 13:03:36
does anybody know where you check the oil in the transmission. I just bought the machine and I am waiting for a repair manual. The machine surges when you move it.I hope it is just low on oil.
marlowe
09-22-2001 18:11:28
 Re: 200 dozer transmission oil in reply to kene senske , 09-22-2001 13:03:36
trans. fill and dip. is just in front of and a little to the left of the left hand stering leaver use sae 90 ep but this will not make it jump it might be the hyd. reverser trans.the dip stick is under the foot plat form it takes dextron 2 DON'T get the wrong oil in the wrong place need help call me 1-920-446-3296
marlowe
09-22-2001 17:58:50
well first check the hydraulic coupling it is like a car or truck torque convertor but it has to be filled manually ther is on pump that will fill it on the side off the bell housing is a little plate that you open rotate the convertor with pry bar ther are two plugs remove the steel one NOT the plastic one fill to leavel of plug hole with dextron 2
