MF65 DIFF. BEARING PRELOAD PROBLEM
Billy Cathey
09-26-2001 08:30:28
I changed all of the axle seals due to leakage. No bearings or cups were changed. As I put the axles back together I seem to have developed an extreme amount of diff. bearing preload, to the point that I can't turn the axles even before the axle tubes are completely tightened. The only thing that I can see that it could possibly be is that I got the carrier plates switched. Any help is greatly appreciated.
Billy
Billy
09-28-2001 11:55:59
 Re: MF65 DIFF. BEARING PRELOAD PROBLEM in reply to Billy Cathey, 09-26-2001 08:30:28
Problem fixed. I had switched the carrier plates.
Thanks Dean.
