TO-35 leaking out pto
Buddy
10-02-2001 19:24:27
Hey guys, this looks like the place with all the answers. Please help. I just bought a TO-35 but know little about tractors. It leaks a lot of gear oil out the pto shaft in the rear. How does this bearing or seal come out? Do you have to tear the rearend apart or does it come out the back? Is there an easier way to fix it? It leaks apout two quarts a day just sitting there. Needs fixed quick i can't affort the gear oil. Thanks in advance. Buddy
smokey
10-03-2001 21:24:39
 Re: TO-35 leaking out pto in reply to Buddy, 10-02-2001 19:24:27
Probably similar to my MF135. Jack up tractor as high as possible at the rear- so as to not loose to much oil. Undo retaining bolts and pull.
This may help - Link
