Just returned home from looking over a pretty good looking tractor for 1 1/2 hours.Has good sheet metal with no rust and no dents. Tractor hood has been repainted with all other paint original paint. Only fluid you can see is a little fuel around top of the fuel pump. No oil or hydraulic leaks. Has one set of remote hookups . Cranks easy and runs good. No smoke even when first cranked or no odd noises . Reacts well to throttle. Checked all the fluid, lift, etc. Got on it and drove it around in most of the gears. No noise at all in the transmission or rear end. Has good rubber(75%). Meter says it has 2900 hours. Seller is not the only owner and couldn't guarnatee the hours. Has good oil pressure. Bracket that holds alternator has been cracked and repaired. New alternator and battery. Has WIDE rear tires 16-18 inches? Spin out rims. Any idea about what it might be worth? Fellow is asking $6250. He agreed to service the tractor with new oil and filter and new hydraulic fluid. Agreed to order me a 7 foot king cutter or Howse cutter at cost. Will deliver the tractor and cutter to me 50 miles away as part of the deal. Fellow pointed out the minor items above to me when I asked him if he knew any problems.
