MF 165 Fuel leak
Billintx
10-07-2001 20:33:05
Fuel has started leaking from the top of the injector pump on my MF 165. It is coming out at the fuel shut off lever. Is there a seal I can replace. The tractor runs fine other wise.
Bill
Big Dean
10-08-2001 07:49:21
 Re: MF 165 Fuel leak in reply to Billintx, 10-07-2001 20:33:05
There is an O-ring on the shaft if you replace it you will probably need a new gasket for the top of the pump. Be careful to get the spring hook back in the same holes it was hooked into. & make sure the peg & slot mate up on the shut of arms when replacing the top.
