30 in first
Eric
11-07-2001 19:46:27
I was driving my massey 30 in a parade and i had to back up and i put it in first and it wont come out, i made it through the parade and it took me 3 hours to go 5 miles home please help me so i can get it workin the right way thank you
p.s. please email me at ericplatz05@hotmail.com
BlueLite
11-13-2001 09:05:16
 Re: 30 in first in reply to Eric, 11-07-2001 19:46:27
Is your shift lever suddenly floppy?. Could be the end of the arm that sits in the shifter blocks has broke off, or if it's intact, check to see if the ball socket snap ring hasn't come loose (just under the boot). You'll have to remove the shift cover plate to check out the innards. With a tire iron you can insert it in the "First" shifter block and try to slide it by hand. If it won't budge then the problem is beyond me. Putting the plate back on, you'll have to
ensure that the PTO shifter fork is in it's slot. My first gear comes out of gear on heavy loads, but that's due to the rail balls being worn, and I can live with that.
