MF 135 Fuel Injector pump leaking
Bill
11-10-2001 05:46:57
My Massey 135 is leaking fuel from the throttle and shutoff valves (on top of the injector pump)Fuel leaks over front areas of the engine. Is there a simple way to correct this without removal/replacement of the pump?
Bob in CA
11-10-2001 08:30:18
 Re: MF 135 Fuel Injector pump leaking in reply to Bill, 11-10-2001 05:46:57
I have solved this leakage problem by removing the top off of the injection pump and replacing the o-ring seals around the two shafts. I purchased standard o-rings from a parts store. It has been a couple of years and they still seal. Good luck.
Bill Cowart
07-22-2002 06:39:59
 Re: Re: MF 135 Fuel Injector pump leaking in reply to Bob in CA, 11-10-2001 08:30:18
I have a case 480d backhoe with the same issue. Fuel leaks out of the throttle linkage at the pump. I am going to attempt this same fix.
