44 G Engine H260 information discrepancy
Steve Powers
11-16-2001 16:52:09
I just pulled the engine from my 44 G. It has H260 stamped on the crank and on the right side of the block. All the sleeve kits I have located call out a 3 7/8 sleeve. But mine is 4 inches inside diameter. I am beginning to wonder exactly which tractor I have.
It has no identiplate. The guy who sold it to me said it was a 44.
Can anyone help with locating the correct sleeves and possibly tell me how I might identify this tractor for sure.
All help appreciated.
Tom
11-17-2001 15:30:45
 Re: 44 G Engine H260 information discrepancy in reply to Steve Powers, 11-16-2001 16:52:09
The model of the tractor should be stamped on the top of the rearend up under the PTO on/off lever. The model number is on top and right under it is the tractor serial number.
Example
44GR
57443
Alan
11-16-2001 17:23:29
Steve, Either the factory or more likely a previous owner bored this block to the 277 cu in. The stroke on both motors is the same. I ASSUME the crank is as well. (anyone know for sure?) Try looking for kits for 44 specials and 444's. Good luck - ALAN
Alberta Jack
12-22-2001 15:49:05
 Re: Re: 44 G Engine H260 information discrepancy in reply to Alan, 11-16-2001 17:23:29
The engine you have has been bored and pistons from a 277 used as Steve said. Crank is the same.
