318 Perkins knock
Cleve
11-20-2001 08:49:56
Have 285 Massey w/318 Perk and CAV pump. Excessive knock sound at low speed espicially when cold and not under load. Sound comes directly from upper engine block in #3 cyl. area when listening with stethoscope. Does not sound like valvetrain, and will quieten out after warm and under load, but will return when ideling.
Replaced pump with rebuilt unit at overhaul just over 100 hrs. ago, and noise has been there since then. Tried retarding pump with little success or effect on noise. Otherwise, it runs fine with minimal smoke and good power.
Can one line on pump be over advanced? What would be the effect of a piston installed backward?
TAZ1206
12-30-2001 14:30:18
 Re: 318 Perkins knock in reply to Cleve, 11-20-2001 08:49:56
HI,IF I WERE YOU I'D PULL OIL PAN ,AND CHECK THAT THE RODS ARE INSTALLED CORRECTLY,FOR THE PRICE OF AGASKET WOULD ALSO BY PEACE OF MINE.PISTON OR ROD REVERSED WOULD CAUSE KNOCK.THEN CHECK VALVE TRAIN,IF ENGINE DOESN'T MISFIRE IT'S NOT AN INJECTOR. LUK 2 YA TAZ
Bob
11-22-2001 06:37:40
You may have a bad injector. I have been told that if they are not spraying correctly they cause a loud knock.
