Problem with power steering
charles cook
11-28-2001 11:55:15
i have a mf model 245, i have lost the power steering on it. i need info on step by step procedure to find the cause. is it the pump, the cylinder, or the box at the base of the steering column. turning the steering wheel does not move the wheels.i raised the frontend and this allows slight movement of the wheels. i disconnected the hose to the cyl. there seems to be fluid flow thru the cyl. fluid level is ok. what next? plrase email me, thanks
Brokenwrench
11-29-2001 16:45:24
 Re: problem with power steering in reply to charles cook, 11-28-2001 11:55:15
If you can't steer the tractor with the front wheels raised there is a good possibility that the spindles are frozen. Try unhooking the tie rod end off of the spindle, and try to turn the spindles. If they won't turn, take steering arm off and drive or press the spindle out and clean everything up. grease everything up and reassemble. Its a good idea, to take the weight off the front end when you grease it this allows some grease to get under the lower bushing.
