MF235/ To-35 Hybred
A. D.
11-30-2001 23:30:39
I have a Mf 235 with the steering,instrument cluster, and front sheet metal off of a To-35. Only guage that works is the oil pressure. The tractor has the MF 235 3 cyl diesel.I looked in my Mf 235 Repair manual and it only mentions that there is a tach cable that needs to be disconnected when removing the engine. The picture shows that it is on the rear of the motor. I can't tell from the picture much about the hook up. My Question is which tach cable should I try to locate the 235s or the to35s. Will it work? Thanks.
Russ
12-04-2001 18:04:23
 Re: MF235/ To-35 Hybred in reply to A. D., 11-30-2001 23:30:39
On the AD3-152, the tach cable screws onto the back of the block on the right hand side. The spring shaft (for lack of the right term) inside the cable assembly is square on the end and fits into the end of the camshaft. The tach end is much the same.
Hope that helps
