MF 35
Brian
12-08-2001 17:17:33
Help me please. I recently bought a 1962 MF35 Deisel. From what I understand it has the Perkins regular injected engine. What I don't know or understand fully is an option called "Multi-Power". This consist of a lever marked High and Low on the right side of the panel. Any information about this option would be of great assistance. The tractor runs fine and seems to be problem free (after installation of the new clutch and auxillary pump to run the loader) but I am still interested in learning more about this tractor. It's replacing a Ford 2N and John Deere Model M so as you can imagine I have entered a new world of tractors. Thanks for your help
Francois
03-27-2002 00:00:19
 Re: MF 35 in reply to Brian, 12-08-2001 17:17:33
what loader do you have on your mf35 l do have a fe35 and i am looking for a front end loader
thank Francois
martin G.
12-16-2001 17:13:17
Hey Brian, can you tell me where your auxilary pump is located on your 35? Did you get it used or new? If knew where?
Thanks for your time
Brooks
12-08-2001 22:24:52
Multi-Power was a "shift-on-the-go" option. It gives free-wheeling in "High" - so be careful!! There is no engine breaking in High. This option was noted for causing troubles - often the operator allowed the tractor to "free wheel" in high before he woke up and then when he shifted to Low there was a CRUNTCH!/BANG!/JERK! as the transmission was forced into Low. It is/was expensive to repair after a lot of such treatment. The shifting is done hydraulically. If you have a typical 6 forward, 2 reverse transmission then MP gives you 12 forward and 4 reverse gears! A lot of choices in '62. My opinion is if the transmission fluid is kept clean and/or replaced according to instructions (and the operator stays awake) that most of the MP problems don't happen.
Brooks
12-08-2001 23:03:40
 Re: Re: MF 35 in reply to Brooks, 12-08-2001 22:24:52
Rats!
Free wheeling is in Low not High. I guess I am dyslexic!
Sorry for any confusion.
Brooks
Scottish Jim
12-14-2001 13:41:26
 Re: Re: Re: MF 35 in reply to Brooks, 12-08-2001 23:03:40
A word of warning I had a real nasty experiance with a 35x multipower , coming to a junction with an implement raised right up in M/P.high I inadvertaintally dropped it into low, wow no braking and an unstable tractor . Instant trouser filling moment I can tell you
