Chrysler Industrials
Allan
12-15-2001 20:16:37
Does anyone know or have info on the models for Chrysler Industrial engines ( the old flatheads).
I have a T100, and a T112. Whats the difference?
ALAN
12-17-2001 17:34:57
 Re: Chrysler Industrials in reply to Allan, 12-15-2001 20:16:37
Found a place (appearently in Mexico because it's in Spanish too) that sells liners for the T112 engine used in "Massey combine No.21" However, the bore on a T-112 is listed as 3.25 inches which is the same as the 217.7 cubic inch L-head engine specs shown in my ref books under the post 1940 101 Super. The stroke for the T112 I couldn't find anywhere but you should be able to check that if the motor's not seized. Hope this helps - ALAN
Roger A. NY
12-17-2001 15:42:03
Allan,
I don't know how much I can help you but here is some info from an old I&T manual.
The MH 101 used a Chrysler T57, T81, or a T105 and all of these engines had the same bore and stroke of 3 1/8 x 4 3/8. The 101 Super used a T96 or a T116 with both engines having 3 1/4 x 4 3/8 Chrysler.
A MH 201 used either a T100 or a T120 with both engines having a 3 3/8 x 4 1/2 bore and stroke. I don't know what the difference is in the engines number even though they used the same bore and stroke.
I also do not have any info on a T112 eng.
Hope this helps at least a little. Roger
Dave_Id
12-16-2001 09:15:43
Just guessing, but the Massey Harris 101 had the Chrysler and so did the Massey Harris 101 Super. I know the Super had a bigger engine. I don't know if the T100 or the T112 appeared in either one of these tractors.
Allan
12-26-2001 19:34:02
 Re: Re: Chrysler Industrials in reply to Dave_Id, 12-16-2001 09:15:43
Thanks for the help guys. I think we got it figured out!
