Fuel mix?
chris mf-35
01-07-2002 20:24:12
i've hear about fuel mixing from the brits, petrol and parifin (gas and kerosine for us americans) what engines are you running it in and in what ratio? what are the advantages? mine is a z134 continel engine and i've been told they were designed to run on about 65 octane. however it runs grreat on 93 octane. thanks for any help.
Pete Tatham
01-12-2002 02:48:42
 Re: fuel mix? in reply to chris mf-35, 01-07-2002 20:24:12
You mean T.V.O., (tractor vapourising oil), which is made up of 85% paraffin, 10%petrol and for an upper cylinder lubricant, 5% diesel. T.V.O. is used in engines with a very low compression ratio. The Ferguson TED had a compression ratio of around 5:1. Regards,
Pete.
