MF 165 Alternator
Big Jim
01-09-2002 09:07:29
I have a 165 with a 203 Perkins diesel engine. The generator is shot (bad armature). Its $85 for a rebuilt one plus they recommend a new regulator ($35) to be installed at the same time. I don't really care for generators and would just as soon install a modern alternator set up with a built in regulator. The problem is the generator is located on the right side of the engine sort of "down in a hole" with a casting right next to it. There is just enough room for the generator, but not enough room for an alternator as they are larger in diameter. The alternator would have to be mounted way out from the engine with a real long belt. I looked at some other MF 165's at our local dealer, but they all had generators too. Does anyone out there know of any 165's with a reasonable looking alternator set up and if so how would it be done? Is there any such thing as a "skinny alternator" that could be mounted right where the generator is? Any help would be appreciated.
LANCE
01-09-2002 20:20:05
 Re: MF 165 Alternator in reply to Big Jim, 01-09-2002 09:07:29
HELLO JOHNNY THE BEST THING TO DO IS CHANGE OVER TO A DELCO ALTERNATOR WITH INTERNAL REGULATOR.YOU CAN BUY THEM AT YOU LOCAL AUTO PARTS STORE FOR ABOUT $50.00 .THE LATER 165 USED AN ALTERNATOR BUT WITH AN EXTERNAL REGULATOR.YOU CAN BY THE BRACKETS NEW FROM YOUR DEALER OR FROM A SALVAGE YARD.IF YOU NEED PART NUMBERS OR A WIRING DIAGRAM EMAIL ME AND I CAN HELP. I HAVE DONE A LOT OF THESE IT IS NOT TO HARD. GOOD LUCK LANCE
Johnny in E.Tx
01-09-2002 16:23:25
I have always had good luck having my generators rebuilt, we have a local electric shop that does excellent work. If your tach cable mounts to the back of the generator you will have to somehow deal with that if you do an alternator swap. You might take a look at the later models to see how they mount,255,275,etc., might could buy what you need from a salvage yard. I'd keep the generator, they are dependable and $120 ain't too bad., just ain't worth swapping in my opinion.
J.R. KS.
01-15-2002 19:39:38
 Re: Re: MF 165 Alternator in reply to Johnny in E.Tx, 01-09-2002 16:23:25
I HAVE A 1971 MF165 WITH ALTERNATOR, THE TACH IS DRIVEN FROM BACK OF ALT. THIS IS A DELCO ALT. THAT APPEARS TO FACTORY ORINGINAL. THE TROUBLE WITH THE DELCO, AUTO ALTS. THEY DON`T HAVE TACH. DRIVES. I HAVE ONE OF THESE ONE WIRE DELCO ALTS. ON MY FORD BACKHOE, IT WORKS GOOD, BUT IT`S NOT IMPORTANT ON IT TO KNOW R.P.M., J.R. KS.
