MF 175 hydraulic fill and drain
Barnes
01-15-2002 12:15:37
Could anyone tell me where I can drain and fill the trans/hydraulic fluid on my mf175? The manual I have shows the dipstick but doesnt mention where the fill and drain locations are.
Big Dean
01-15-2002 17:18:39
 Re: MF 175 hydraulic fill and drain in reply to Barnes, 01-15-2002 12:15:37
The Transmission, Hydraulic & Differential oils are all contained in a common reservoir. There are two drain plugs for them on the left bottom one on the transmission & one about 3/4 of the way back on the rear housing. You need to drain it in both places. To fill remove the Big Plug just left of the Main shift lever. Fill with 8 Gal. of good Trans/hyd oil. Massey Perm-A-Tran-III or the old # was M1129A Any oil that meets these oils specs. will work.
