TO-20 Wheel Weights?
brandt
11-26-1998 21:05:28
I have a TO-20 which I have used for years with
two mis-matched rear tires. Worse, only one has
fluid and it is the newer one. I have not added fluid to the old one, assuming that it will give
out immediately after it is tampered with. I really
would like to restore the finish on my wheels and
get a matched set of tires but I really don't want
to mess with fluid in them (I have already ruined
tools which came in contact with the calcium chloride).
My question is, are there wheel weights that fit my
Fergy? I really need the traction when pushing snow
and I use a 3-point blade so I can't really add weight
there.
E.Allison
11-30-1998 09:24:37
 Re: TO-20 Wheel Weights? in reply to brandt, 11-26-1998 21:05:28
I have a set of wheel weights from a TO-30 I don't need, but shipping could be nasty. There in central PA. EE Allison
: I have a TO-20 which I have used for years with
: two mis-matched rear tires. Worse, only one has
: fluid and it is the newer one. I have not added : fluid to the old one, assuming that it will give
: out immediately after it is tampered with. I really
: would like to restore the finish on my wheels and
: get a matched set of tires but I really don't want
: to mess with fluid in them (I have already ruined
: tools which came in contact with the calcium chloride).
: My question is, are there wheel weights that fit my
: Fergy? I really need the traction when pushing snow
: and I use a 3-point blade so I can't really add weight
: there.
RWK in WI
11-29-1998 17:17:43
: there.
I have a TE20 and for a while I was using it with a back blade also. I had a set of Ford pie weights on and hardly needed the chains until things got icy. Ford pie weights have an adaptor plate that bolts to the hub using adaptor stud/bolts and present wheel lugs, then 12 pie sections on either 30 or 40 pounds each bolt to the plate. Pie weights came in two sizes ( weights ) They work great but may be hard to find.
Dick
