Re:Murphy switch?
Bill
12-14-1999 18:12:59
I have a MH30STD and want to use a PTO generator.
I am wondering if there is device that can be wired into the tractor that will shut down the motor if the oil pressure drops and/or the motor overheats. I had a conversation with a person who thought there was, and it's called a "Murphy switch". Anybody out there have any information on this or anything else that might do the same thing?
Thanks, Bill
Larry
12-15-1999 20:55:49
 Re: Re:Murphy switch? in reply to Bill, 12-14-1999 18:12:59
check out www.murphyswitch.com
Martin Nadolski
12-08-2001 06:36:01
 Re: Re: Re:Murphy switch? in reply to Larry, 12-15-1999 20:55:49
Where i found price Vibration Switch High VS-2EX?
Could somebody help me?
Jack in NB
12-15-1999 04:12:48
Hi Bill -
Good thinking!
The irrigation folks have Murphy engine protection components on the shelf. Sort of mix and match for your particular application and power plant.
Merle
12-14-1999 21:00:35
Talk to a GM parts person and they should be able to help you out. When I swapped engines in my blazer remember something coming off the oil filter housing. After looking at the engines wiring diagram it was a oil pressure cut of switch. Good luck and Merry Christmas
Merle
