FE-35 frontend loader
Charles Poole
12-14-1999 19:56:33
looking for info on a front end loader manu. by midwestern industries mod=101 II, ser# 22224. need the shaft to connect to the engine front pulley. local massey dealers have the pulley attachment and different length shafts but dont know which length and will need adapter to attach to hyd pump. are midwestern parts available? the loader came off a 35 so i know it will fit.
Elmer
12-15-1999 04:31:35
 Re: FE-35 frontend loader in reply to Charles Poole, 12-14-1999 19:56:33
Was this a tube type loader provided by Massey. I have operators manuals for the FE35 and i am sure i saw one for a loader as well. If you want copies i can help you out.
Charles
12-15-1999 20:19:43
 Re: Re: FE-35 frontend loader in reply to Elmer, 12-15-1999 04:31:35
the loader does not have a massey name on it and is not designed to "drive into".looks as though will have to attach belly frame and leave on the tractor and remove pistons and arms, disconnect hyd. lines to remove lift portion. a friend familier with massey loaders told me the massey can be driven into and hooked up with a few pins.i do appreciate and accept the offer for the manual. what do i need to do to get it.any knowledge will help in all endevours.
thank you
charles
