175 clutch slip
Dan
03-08-1998 05:56:48
My 175 diesel clutch started slipping, is the only adjustment on the clutch shaft? also the multi power started leaking out the bell housing when it is in high range, could this possibly be the problem, and if so do i need to split the tractor to fix? I appreciate ay help.
e
Gerald
04-28-1998 14:21:18
 Re: 175 clutch slip in reply to Dan, 03-08-1998 05:56:48
: My 175 diesel clutch started slipping, is the only adjustment on the clutch shaft? also the multi power started leaking out the bell housing when it is in high range, could this possibly be the problem, and if so do i need to split the tractor to fix? I appreciate ay help.
: e
I suspect the multipower control valve. Its in the top of the clutch bell housing and only pressurized when in high range. I don't think you can get to it from the clutch inspection plate on the bottom of the clutch bell (presuming its similar to my 135 that I think may have to same problem). I fear the tractor will have to split and the seals or the multipower control valve and/or plumbing replaced. You could keep the multipower in low and not put pressure on whatever leaks, though I keep finding it so useful.
