How to remove wheel bearing cap?
165TN
01-27-2002 06:44:44
Can someone tell me a good way to remove the front wheel (aluminum raised Y) bearing caps on my MF165? Thanks for any help.
thebigron
01-27-2002 17:11:05
 Re: How to remove wheel bearing cap? in reply to 165TN, 01-27-2002 06:44:44
They are righthand threaded. Might want to soak them a little with WD-40 or whatever. Probably want to use a hardwood block struck with hammer to keep from bending ears of the "Y". A little never seeze might be good to go back with
J.R. KS.
01-27-2002 17:08:50
THEY UNSREW, WITH RIGHT HAND THREADS. USE A BIG PAIR OF WATER PUMP PLIERS. WHEN INSTALLING CAPS USE ANTI-SIEZE COMPOUND ON THE THREADS.
