BRAKES ON FE35
bob
01-31-2002 11:40:34
I restored a FE35 10 years ago and am now giving it another but the brake drums refuse to come off, i've tried hitting them, heating them and tried a puller but to no avail.
The brakes are twin shoed,as it was built as an industrial tractor and the hubs are obsolete.
As a last coarse I may be able to change the whole brake hub and housing for a MF 35 but I would rather just reline the existing.
any ideas? Bob from the UK
Roger
02-01-2002 12:22:48
 Re: BRAKES ON FE35 in reply to bob, 01-31-2002 11:40:34
Bob;
Going from memory, there are two large slotted
screws (head about 1" in diameter) on each drum
which retain the drum to the rear axle shaft flange.
The slot is larger than any screwdriver I've ever
seen so you might try a piece of flat stock and a
crescent wrench or some other combo...
Good luck,
Roger
