Front mount hydraulics
Bert
02-04-2002 18:25:45
I have a gear pump I,d like to mount but don't know the size(GPM) is there any way to tell by taking the pump apart? Can I use my tractors hydraulic reservoir or do I need a new tank?
gary
02-04-2002 18:46:29
 Re: front mount hydraulics in reply to Bert, 02-04-2002 18:25:45
Hi Bert. In order to find out what the capacity and pressure of your pump you need to know the Brand and model\serial # of the pump. The manufacturers name is usually cast into the pump body and model and serial numbers are usually stamped on to a flat spot somewhere on the pump. Once you have this info call a hydraulic supply company near you. Most of these guys are helpful and should be able to look up your pump specs . You probably could use your existing reservoir. you will need to have a supply and a return port also you should have a filter in the return line. What type of fluid are you using and how large (gallons\quarts) is your sump? What do you intend to use the hydraulics for?
gary
Bert
02-05-2002 16:03:36
 Re: Re: front mount hydraulics in reply to gary, 02-04-2002 18:46:29
Gary: Thanks for the info. The pump is going to run an allied loader and my sump will hold about 8 gallons of combination transmission/hydraulic oil.
