135 hydraulic filter replacement.
Bill in TN
02-14-2002 17:29:31
How much trouble is it to replace the hydraulic filter on my 70 model 135? Where is it located, and how do I get to it. I have several books but they show detailed disassembly/reassembly and not normal periodic maintenance/service. This is all I lack in getting all fluids and filters replaced. Is this something I should attempt myself? Thanks, Bill in TN
ray-s
02-16-2002 01:03:28
 Re: 135 hydraulic filter replacement. in reply to Bill in TN, 02-14-2002 17:29:31
Don't forget to fasten the wing nut with wire.
Bob in CA
02-15-2002 16:52:20
The best way to get to the filter is through the left side cover with the PTO shifter attached. Remove the cover and then the screen can be unscrewed. Mine is secured with wire so you have to cut the wire before unscrewing. The filter is a fine stainles steel screen so it can be washed and then replaced. I have used the right side cover to clean it before because I already had the cover off but I think it should be easier through the left. Not difficult to do.
Bob
