MF275 Aux. Hydraulic Bleed?
Andy McDowell
02-15-2002 09:47:05
Using a front end loader, vertical control is okay, the bucket stays up. But the tilt is another story, it loses pressure and slowly tilts down, making it impossible to use the bucket. Bleed? Gasket? Already put in new hyd fluid and filter, to no avail.
marlowe
02-15-2002 16:25:06
 Re: MF275 Aux. Hydraulic Bleed? in reply to Andy McDowell, 02-15-2002 09:47:05
also check for a bad piston packing in the ram
Johnny in N.E. Tx
02-15-2002 13:43:01
Sounds like your spool valve might have a bad O-ring, take it apart and give it a look, or if you could swap the tilt and up/down valves and your problem also swaps, then it just might be your valve.
