1085 hydraulics, serviceman?
rhudson
02-15-2002 10:59:09
MF 1085 with cab. 3 pt hitch raises when tractor is cranked the only way to get load down is to use the inner lever allway forward, dumping pressure off the pump. i've been told that if you don't use the 3 pt hitch often on these tractors that the control valve sticks in place. i have taken the access cover off the right side of the tractor and tried to move the valve control lever by hand. no change at this point. for those of you that have worked on this problem before. how much manual pressure should i try to apply against the lever?. is there a special tool i might fabricate to help? should i be trying to move the valve spool itself instead of the attached lever? signed "afraid of the repair bill if i can't fix"
