3 pt won't lower w/out load on it.
Loren Brown
02-05-1999 21:11:26
I recently purchased a M-F 2135 Turf Special, although it appears to have been adequately maintained, I've been doing the maintenance stated under the hood, filters, oil changes, coolant, etc even cleaned the hyd filter. Anyway I've hooked up a disc and a mower and the 3 pt raises, lowers, and holds ok, but without a load (nothing hooked up) it doesn't want to lower, any help, a common problem? Am new to tractors but have hyd exp with years of commercial fishing on the we
James Mueller
01-17-2000 18:06:10
 more power in reply to
Tyler(WA)
01-18-2000 13:58:31
 Re: alternator on MF 1100 in reply to Eric, 01-17-2000 06:37:57
Check your e-mail.
rod
02-09-2000 04:49:22
 Re: MF35 trans. stuck in reverse help please in reply to AL Crocco, 02-09-2000 02:03:08
First relax this is quite common after the slots get worn you can remove the top of trans cover or if you have a filler hole there on top remove that and use a flat screw driver to move shifter out of stuck gear usually first reverse is the one. I built up the shifter ball on mine and it has not stuck again so far. Mean while you can visit or join up below lots of knowledge there.
regards
rod
