MF 135 Vineyard
Bob Kirk
01-03-2000 09:18:03
I have been looking for a utility tractor something like the MF 35. An ad was just listed on this page (non-photo) for a MF 135 "Vineyard" (gas).
Does anyone know, or can you point me to a source, for figuring out what all the special features of the "Vineyard" model were?
Also, was there a single gas engine used in these? Any special reputation -- especially for easy starting after periods without use?
Thanks very much.
Bob
Gerald J.
01-03-2000 10:47:06
 Re: MF 135 Vineyard in reply to Bob Kirk, 01-03-2000 09:18:03
There were two gas engines used according to vintage. A 4 cylinder Continental Z145 or Z134 before 1969, a 3 cylinder Perkins after that.
With care I know the Continental starts after being ignored, though any carburetor can gum up and any condenser can go bad from moisture.
As I recall my owner's manual and parts book the Vineyard tractor has a different front axle and maybe different rear wheels and tires.
Gerald J.
mike
01-03-2000 21:46:41
 Re: Re: MF 135 Vineyard in reply to Gerald J., 01-03-2000 10:47:06
vinyard--swept back front axle to make tighter turns,out board drum brakes. mrtractor.
Gerald J.
01-04-2000 08:46:37
 Re: Re: Re: MF 135 Vineyard in reply to mike, 01-03-2000 21:46:41
As far as I can tell all MF-135 had outboard dry drum brakes.
Gerald J.
mike
01-05-2000 22:00:53
 Re: Re: Re: Re: MF 135 Vineyard in reply to Gerald J., 01-04-2000 08:46:37
GERALD J. ALL!!! mf135 orchard tractors have inboard brakes and heavy duty straight front axle---ALL mf 135 vineyard tractors,drum brakes and swept back axle. mike-mrtractor.
Bob Kirk
01-06-2000 07:33:45
 Re: Re: Re: Re: Re: MF 135 Vineyard in reply to mike, 01-05-2000 22:00:53
Mike:
I see the turning radius advantage of a swept-back front axel. Is there any advantage/disadvantage to drum vs. inboard brakes (I have worked on auto drum brakes but have no idea what the "inboard" configuration entails.)
Thanks for your help.
Bob K.
mike
01-09-2000 22:17:09
 Re: Re: Re: Re: Re: Re: MF 135 Vineyard in reply to Bob Kirk, 01-06-2000 07:33:45
Bob,inboard brakes are inside the rearend housing on the real late models they even run in oil-look at the back of rearend housing notches in the plates means oil brakes-no notches no oil ,oil is better.drum brakes easy to change-work ok. inboard brakes hard to service but are much tuffer. mike@mrtractor.com
Gerald J.
01-06-2000 15:56:04
My MF-135 Deluxe has drum brakes outboard, the wheels bolt to the drums. I'll have to go study the parts book. I'd not noticed inboard brakes in the 135.
Gerald J.
