Independent brake?
A. D.
02-24-2002 20:23:06
Been working on my hybred Mf 235/TO35 and am working on removing rear drums to check brake linings. Have read post on how to get them off. I am curious just how efficient should the brakes be on helping turn the Massey. From my memory I can make it turn one better than the other. ( can't remember which way is best). On the side that the brakes don't help very much on You have to litterally stand on that brake for ANY help in turning. I have driven other tractors (All newer) that will " turn on a dime" when using independent brakes while turning, some will actually pivot on the inner tire. Should tne Massey be expected to be able to pivot this way or am I asking to much?
Eric
03-17-2002 07:06:15
 Re: independent brake? in reply to A. D., 02-24-2002 20:23:06
Yes, those brakes should help in turning, we have a 22, 30 and a 44 and all of them turn on a dime with brake applied, with a wide front tractor it still helps alot but you cant turn as sharp as a narrow front
LANCE
02-25-2002 19:56:07
TELL US ABOUT YOUR MF235/TO35 I WOULD LOVE TO HERE WHAT YOU ARE DOING. LANCE
