MF 25
Chad S
03-05-2002 17:44:01
Hi Gang,
Was looking through the local Ag paper and saw an ad for a MF 25. I have been looking for a small utility tractor in the 25HP range and the only specs. that I have been able to find on these is that they were French built with a 4-cylinder diesel. Does this tractor have a standard 3 point and live lift / live pto like the 35 series or? Any other thoughts or info would be greatly appreciated.
Thanks,
Chad
Dr. Frankenstein
03-07-2002 13:43:02
 Re: MF 25 in reply to Chad S, 03-05-2002 17:44:01
The MF25 is made in Paris France similar to the 130, has PTO and lift. There are versions with single and double clutch, 4 syl 107 cu.in. Perkins diesel. Lift with draft control. 4 x2 forward end 2 x reverse gears.There are pictures of my 25 in the photo galery. search for MF25. Quite rare on this site. The tractor itself seems to be quite rare too.
In europe parts are available, mostly trough the MF dealer.
StiG D.
03-28-2002 14:01:26
 Re: Re: MF 25 in reply to Dr. Frankenstein, 03-07-2002 13:43:02
I've just bought a 25.
Any suggestions where to find a shop manual?
The lift don't lift.
There is a lever on the right side of the tranny, just inside of the hydraulic control. This is made of alu.
It is all "loose", what should this lever do?
