Massy 35 fluid leak
charlie
03-10-2002 07:05:47
Have a massy 35 diesel. Right below the gas tank and battery there is a lot of little gas lines that run from the tank to the two fuel filters. It looks like it is leaking diesel at all them little fittings. I tried tightening them but it still is leaking. Are them fitting replacable or what should I do.
Thank you
Orlando: Volant, PA
03-10-2002 17:14:14
 Re: Massy 35 fluid leak in reply to charlie, 03-10-2002 07:05:47
Charlie: I am assuming that this diesel is a 3 cyl. perkins type? There should be a shut off valve on the bottom of the tank with a braided fuel line that crosses over to the water separator and lift pump. The line has (or should have) a curved metal end with compression fittings into the water separator glass bowl unit. This line can be replaced with minimal effort. Do NOT over tighten the brass fittings on the line. That may be your problem. If the separator/lift pump assembly is leaking..there is a rebuild kit ($44) with gaskets, brass filter screen,etc., or you can buy a rebuilt/new unit for around $66-70 or so from a MF dealer. Personally, I would buy the new unit if you could afford it. Hope this helps. Orlando
