165 clutch adjustment
AW-1
03-10-2002 07:06:17
I'm not sure how to adjust clutch correctly, need help. the pedal is all the way at top.
Bonnie Giles
09-06-2004 17:43:24
 Re: 165 clutch adjustment in reply to AW-1, 03-10-2002 07:06:17
This is how one adjusts the 'clutch pedal', but not the clutch itself. I adjusted the pedal as mine too is at the top. When I adjusted it lower than that, the clutch dragged as when I put it in gear, it lurched forward a bit and then I could not get it back out of gear until I shut it down and let the pressure subside. Then it came back out of gear. I have now put it back to where it was and can use the tractor, however, it seems adjustment of the clutch itself is enivitable. Is there an easy way to do this?? Please help. I am not overly 'mechanical', but with good instructions, I think I can do this.
Thanks guys for helping out a girl learning her way around a British Diesel rig. :o)
Bonnie
Don
03-10-2002 10:29:32
The adjustment is really quite easy. There is a turnbuckle under the pedal, just pull the bottom pin, and loosen the locking nut. extend the turnbuckle to adjust properly. usually doesn't take much to adjust it. Good Luck
Don
