175 transmission leak
Bob in Ga
01-04-2000 22:41:41
I have a leak coming from the opening in the housing right behind the motor. It is a steady drip while the engine is running. It is coming from the section between the motor and the transmission. I assume it is coming from the transmission. Is there maybe a seal in there that might be leaking? How difficult is it to seperate the tractor in the middle and repair this problem? I have been a pretty good shade tree mechanic on automobiles but have never worked on tractors very much. Also what type of fluid goes back in this transmission?
Elmer
01-05-2000 04:41:37
 Re: 175 transmission leak in reply to Bob in Ga, 01-04-2000 22:41:41
Leak is likely at the input shaft. Do you have multi-power.
