Pto shaft stuck
brian
03-15-2002 16:02:29
i have a f40 and the pto shaft leaks i unbolted the pto shaft and it still will not come out. is there a snap ring or something else that i'm forgetting? thanks
Phil(va)
10-26-2004 14:37:16
 Re: pto shaft stuck in reply to brian, 03-15-2002 16:02:29
Another tip: Take the pto shaft off an implement, just the slide out part that attaches to the tractor. Then hook it to the pto as you normally would. This will give you a long shaft for leverage, and you can get a friend to help pull this way. I had to do that, and it worked fine, but i couldn't get it by myself just by pulling on the pto.
Big Dean
03-15-2002 17:40:23
The O-ring that seal the retainer is what is holding you stick some in the hole in the shaft pry against the piece stuck through shaft & the rear housing as soon as the O-ring comes out you can remove the whole shaft or you can just slip the seal retainer off the shaft.
