Massey Ferguson 135 Gas
Bob
03-18-2002 01:53:42
I have a real bad power steering leak around the steering shaft, where could I get this seal..please advise.. thanks.. Bob
Roger
03-18-2002 14:25:46
 Re: Massey Ferguson 135 Gas in reply to Bob, 03-18-2002 01:53:42
Bob;
I had the same problem with my TO-35. With all
the different models of MFs, I don't know if yours
uses the same seal, but mine is MF# 1 751 702M1.
It measures 49/64 x 1-3/8 x 25/64". When you pull
the shaft housing to get to the seal, you'll come
accross O-ring MF# 1 751 687 M1 (2-53/64 ID x
7/64"). You might also consider replacing the
bearing (nylon bushing) at the very top of the
housing; MF 1 751 700 M1. I order thru a local MF
dealer and I
think they get most of their parts from TISCO.
Hope this helps.
Roger
