MH30 1st/Rev Shift rail Removal?
BlueLite
03-18-2002 06:55:56
My transmission throws out of gear in first on a hard pull. I know it's probably a worn retainer
ball or weak retainer ball spring on the first/reverse shift rail that causes the problem. My gears aren't worn so I know that's not the problem. Is it a big job to remove the center (1st/R)
rail and change the retainer ball.?
Thanks.
ET
03-19-2002 05:12:24
 Re: MH30 1st/Rev Shift rail Removal? in reply to BlueLite, 03-18-2002 06:55:56
Check the shaft endplay worn bearings can make it pop out of gear.
