44 frontend to 30 tractor
mike
03-22-2002 17:20:35
I have 30 mh narrow front, will the wide front off 44 fit, and what is this worth with wide front end , I'm JD nut so don't much about mh thanks.
GPJerry
03-25-2002 10:27:39
 Re: 44 frontend to 30 tractor in reply to mike, 03-22-2002 17:20:35
They are interchangeable, but not identical. 30's had 15 inch, 5 lug wheels; 44's had 16 inch, 6 lug wheels. The spindle casting is also longer on the 44, meaning that if you just do a transplant, the 30 with the 44 axle will be several inches taller in front than it should be.
Tom
03-22-2002 19:40:29
A 44 wide front end will fit a 30. Not knowing any details about your tractor it would be hard to place a value.
