Massey Harris
Chuck Strey
03-26-2002 19:30:56
My Father bought a Massey Harris Tractor use and we would like to know how to find out the model of the Tractor.
Alberta Mike
03-26-2002 20:34:08
 Re: Massey Harris in reply to Chuck Strey, 03-26-2002 19:30:56
The tin plate with the model number and serial number is obviously off the tractor. The serial number will be hand stamped into the top of the transmission/differential case on the machined surface between the shift lever platform and the steel plate that bolts down over the differential. It will be on the clutch side and you'll have to do some scraping and wire-brushing to get all the old paint and crud off to find the number but it will be there. Once you have the number, post it here and somebody will ID the model number. I'm not sure if the model number is stamped in before the actual serial number.
Tom W.
03-27-2002 14:06:12
 Re: Re: Massey Harris in reply to Alberta Mike, 03-26-2002 20:34:08
The model number is in front of the serial number. They read 44GR4685.
Alberta Mike
03-27-2002 14:31:14
 Re: Re: Re: Massey Harris in reply to Tom W., 03-27-2002 14:06:12
That would be a 1948 model, the G stands for Gas engine and the R stands for Rowcrop (narrow front). Lots of 44's up here but mostly wide fronts, you'd seldom see a narrow fronted tractor from that era.
Tom W.
03-27-2002 20:21:02
 Re: Re: Re: Re: Massey Harris in reply to Alberta Mike, 03-27-2002 14:31:14
I just made that number up for an example.
Alberta Mike
03-28-2002 07:43:01
 Re: Re: Re: Re: Re: Massey Harris in reply to Tom W., 03-27-2002 20:21:02
You know, I realized that after I made the post since I looked again and saw that I wasn't responding to the original guy who asked the question. Felt kinda silly after hitting the button, but it was a good example.
