165 pto question
Ray
04-02-2002 15:33:07
I have a 165 diesel noticed the pto doesn't stop
with the clutch pushed down.I put the clutch pin
in the top hole to give it more movement,but it
still doesn't stop.I hooked it to a pto alternator
it would keep running until I moved the pto
lever foreward.It goes in and out of gear easily
without any grind.I thought it had a two stage
clutch,but only stops when the pto lever is foreward.Is my clutch bad? Thanks.
jake
04-03-2002 06:47:18
 Re: 165 pto question in reply to Ray, 04-02-2002 15:33:07
are you sure that your massey doesn't have a hydraulic pto? In my mf 168 there is only a hydraulic lever, when pushed into forward position the pto engages.
Big Jim
04-03-2002 13:31:32
 Re: Re: 165 pto question in reply to jake, 04-03-2002 06:47:18
Look down by your PTO lever. If it has written in the casting "engine" and "ground", then you have a two stage clutch with live PTO. It is supposed to stop if you push the clutch down all the way down. If there are a couple of hydraulic hoses coming out of the transmisson housing down by the PTO lever, then you have the fully independent PTO. The only way to shut it off is to move the PTO lever. Most of the 165's had the two stage clutch.
Ray
04-03-2002 17:33:29
 Re: Re: Re: 165 pto question in reply to Big Jim, 04-03-2002 13:31:32
Thanks,guys I've got the two hydraulic lines,
and it doesn't say ground or engine.Just got
this thing,and a massey mechanic said the pto
was out.The owners manual list only a two stage
clutch.
