Pump for 3point
brian
04-04-2002 15:03:02
how hard is it to take the hyd pump out of a f40. the three point is not working so i think this is the problem. and help would be great thanks
BIG Dean
04-04-2002 15:31:03
 Re: pump for 3point in reply to brian, 04-04-2002 15:03:02
You first have to pull the PTO & the lift cover. There are 2 small plates on each side of the center housing with dowles made on them. They stick into the pump end plate. The dowle plates are held on with 2-5/16 bolts. After you get the dowles out of the pump it will slide back & lift out the top of the center housing. If you have questions Email me.
