Grease fitting
Bob S.
04-08-2002 20:21:55
What would cause a grease fitting not to take
grease if it is not the actual fitting? My MF 175
won't take grease at the front end pivot and the
right kingpin even after I put new fittings on.
Everything seems to move smoothly....Bob
Gordon-(TN)
04-08-2002 23:57:27
 Re: grease fitting in reply to Bob S., 04-08-2002 20:21:55
take the fitting out and see if you can get all of that old dried up mess out that the grease gun can't push through the small opening betwene the moving parts. good luck
Gordon-(TN)
Gordon-(TN)
04-08-2002 23:56:28
Gordon-(TN)
George Eddy
04-09-2002 18:50:08
 Re: Re: grease fitting in reply to Gordon-(TN), 04-08-2002 23:56:28
In addition to the previous post . After you have done that some times it helps to jack it up so that there is no wieght on the shaft and then grease it
bob
04-10-2002 17:37:25
 Re: Re: Re: grease fitting in reply to George Eddy, 04-09-2002 18:50:08
also spray some pee oil to soften grease
