1954 Massey Harris 44 Special Ser# 44G1RF54496
Greg Powell
04-12-2002 21:04:44
Need a complete Tie Rod Assy.(left side).
Does anyone know if new parts will interchange from another tractor?
The following is the only numbers I can find:
761805M1 - on Axle Clamps.
764136 - on both right and left Outer Steering Arms.
18MN9 - on Tie Rod Tube Clamps.
Michael
04-13-2002 17:05:53
 Re: 1954 Massey Harris 44 Special Ser# 44G1RF54496 in reply to Greg Powell, 04-12-2002 21:04:44
After market suppliers, like Tisco, will be able
to come close on the ends. I believe MF 35 and
Ferguson 40. Unless you're a real purist, you
could probably get a used rod assembly from a
broken up 44 WFE, at a salvage yard or parts
jockey. Keep in mind what you have, as there are
two Special 'Hi-Arch' similar axles, one w/a
36" center bolster, the second, a 44" bolster. Perhaps you can buy the pair of rods used, and
they will match. Good luck.
