Pony
bob
04-13-2002 16:06:02
can some one tell me where the oil preasure line comes out of the block on a pony?the only place i see is left side below the filler pipe.it has a plug in it and when i remove the plug i dont get enough oil to run a gauge.thanks, bob
Van
04-17-2002 09:25:38
 Re: pony in reply to bob , 04-13-2002 16:06:02
Bob,
Yes that is where the oil line hooks. If your Pony has an oil filter, the line goes up to the filter then out of the filter around the back of the engine to a little distribution block, then to the gauge. If your Pony doesn't have an oil filter, the line goes from the left side of the engine, near the filler tube, up and around the back to the little distribution block, then to the gauge. Depending on the condition of your engine, it might not have good oil pressure.
