TO-35 transmission stuck in 1st gear
Bill Mitchell
04-13-2002 20:55:57
I have a ferguson TO-35 that is stuck in 1st gear do I need to pull the top cover to get it out or is there something simple I can do? It didn't make any noise or anything all of a sudden it just would'nt shift. Any help would be greatly appreciated!!
young restorer
04-16-2002 07:07:25
 Re: TO-35 transmission stuck in 1st gear in reply to Bill Mitchell, 04-13-2002 20:55:57
our MF135 did the same except it stuck in reverse. We removed the cover and just knocked the selector cogg into the correct position and shes never done it since.
Hal
04-15-2002 17:29:50
This is common when the shifting parts are worn. The problem can usually be avoided by not pulling up on the lever when shifting, and by shifting slowly when moving from a gear on the right(2-3) to one on the left(R-1).
Chuck, WA
04-15-2002 13:11:11
My MF35 has stuck twice in 2nd in the month or so that I've owned it. My friend who I bought it from who restores tractors says that's not uncommon in these MFs and some IHs and can be caused by shifting too soon before everything has stopped turning. He says what Chris C. said - screwdriver through oil filler hole to slip gear back. However, last weekend, another friend fixed it in a different way - drove over some rough ground, bounced and heard it click back in. :) I think the first time it stuck for me, that's what fixed it since I didn't do anything else but continue working in 2nd on some rough ground.
Gordon-(TN)
04-14-2002 23:08:41
I have a mf-35 and I have had the same thing happen to it. to get it out of gear I plant both feet on running boards, lift up on gear shift while working it around, It has worked for me every time. hope this helps Gordon-(TN)
Chris C.
04-13-2002 22:38:12
You may be able to free it by using a large screwdriver through the trans/hyd filler cap port. Check Big Deans web site for details. This is pretty common on older Massey fergusons with some play in the shifter sockets
