1969 MF 165
Mark
04-18-2002 10:55:10
I have a 1969 MF 165 S/N = 9A 64458 Diesel, where the 3 pt lift works fine for 4 or 5 lifts with load and then will shutter as it goes up. I may have to pull the hydraulic lift lever ( in front of seat) 4 or 5 times to fully raise the load. The dip stick says full. I can raise a 20 disk harrow OK (4 or 5 times) . I added 10 cement blocks to it and the 3 pt would not raise it. Should this 3 pt be able to raise this type of load.Any suggestions on what to check first would be appreciated.
Rob
04-18-2002 19:58:15
 Re: 1969 MF 165 in reply to Mark, 04-18-2002 10:55:10
I have the same tractor, and I can lift more than that with the lift
