HELP ME AND MY MH 44 H260
charleswhitney
04-20-2002 20:33:48
I HAVE A MASSEY HARRIS 44 WIHT A H260 CONTINENTAL ENGINE I WANT TO OVERHALL IT AND I'M LOOKING FOR SPECS ON THE ENGINE LIKE BEARING CLEARANCES
ALSO NEED DRIVETRAIN SPECS LIKE RING AND PINION BACKLASH SETINGS!
ONE MORE THING HOW DO YOU TELL A 44 FROM A 44SPECIAL AND IS THE FRONT IRON FRAME LONGER ON A 44 SPECIAL ARE THEY JUST SIX CYL 44'S WITH A266 OR 277 IN THEM? IF YOU CAN E-MAIL ME SOME SPECS ON MY 44 H260 GAS
OR SHOW A YOUNG PUNK WHO WAS NOT AROUND WHEN THESE
WERE MADE A FEW THINGS ABOUT 44 SPECIAL'S
E-MAIL ME AT WWW.CHUCKCAT4@YAHOO.COM
THANK YOU ! GOOD DAY!
Bruce Colbourne
04-28-2002 12:20:01
 Re: HELP ME AND MY MH 44 H260 in reply to charleswhitney, 04-20-2002 20:33:48
If you e-mail your correct e-mail address I can e-mail you the specs you are looking for on the engine.The standard 44 uses a H260 continental engine.The 44 special has a longer front frame and uses a H277 continental engine.The engines are the same block and head etc.The pistons and sleeve's are different size's.The 44 special also has a heaver pedestal that holds the front axle.I can also get you dive-train specs.
charlesmy e-mail
04-29-2002 09:23:49
 Re: Re: HELP ME AND MY MH 44 H260 in reply to Bruce Colbourne, 04-28-2002 12:20:01
MY E-MAIL IS WORKING IT MAY HAVE BEEN YAHOO WAS HAVING TROULBE
OR MAY BE NEEDED TO DROP OFF THE WWW.
TRY CHUCKCAT4@YAHOO.COM
IF NO LUCK TRY CHUCKCAT3@HOTMAIL.COM
SORRY!!!!! !!!!! !
AND THANKS!
Alberta Mike
04-21-2002 08:14:51
Are you sure your email address is posted correctly? I responded through the link and got a message back that you are not with Yahoo. Maybe check that out. I emailed you some specs.
