255 MF tachometer cable
Dave
04-27-2002 12:57:58
Got an oil leak caused by broken aluminum cap screw on tachometer cable. Got the cap loose, but cable will not come out. Do you have to take the whole assembly loose to remove the cable (engine end)? I am hoping not, there are forty eleven dozen diesel lines, wires and stuff to work around and about an inch of space to work in, loader frame gets in way too.
H.T.Hertz
04-27-2002 15:59:20
 Re: 255 MF tachometer cable in reply to Dave, 04-27-2002 12:57:58
It is not supposed to leak oil even with the cap off, so something must be done to the seal anyway.
- the hard way...
Henning T. Hertz
Denmark
