Fuel in oil HELP
charles
04-30-2002 07:16:56
I have a MF 70 that gets fuel in the oil??? just checked it and there is about a qt of gas in the pan after 6 months ????is there any other way this can get in othere the back flowing through the intake...there dosnt seem to be any damage to the mains yet .compression is real good with no sign of valve problems ????is there a crank case vent with a popit that i cant seem to find ?????
wayne in TN.
04-30-2002 19:25:59
 Re: fuel in oil HELP in reply to charles, 04-30-2002 07:16:56
I would check fuel pump before I did anything else(and I'm not talking about injector pump on diesel).This would be a cheap fix if this is problem.Good luck!
marlowe
04-30-2002 18:16:20
boy that is a good one!!! do you have a fuel pump on the side of the block? if not boy that is a good one! sure can't is how gas will get in the oil? sorry that one has me stumped
henning thomssen
04-30-2002 18:13:13
the diaphram in the fuel-lift pump might have a small hole in it.that could let fuel leak into the oil!
marlowe
04-30-2002 14:49:45
first is this a gas or a diesel??? at one point you said fuel which i take as diesel then you said gas?? if its a diesel your imput shaft seal is bad on the pump so it will leak in to the oil. if it is a gas your carb is leaking at the needle and seat from a bad needle and seat or a float that is set wrong or busted or sunk. hope this helps
Mikey in MB
04-30-2002 22:49:22
 Re: Re: fuel in oil HELP in reply to marlowe, 04-30-2002 14:49:45
I'd have to agree with the carb problem. We've run into a lot of problems like this on auger motors, etc. and a good carb rebuild usually does the trick.
charles
04-30-2002 17:29:15
this is a gas model . it has an up draft carb ???so i guess my question would be sence i have never had a floading problem is there any way gas can get in the oil with out filling all the way to the top of the intake then filling the cylender to get in the oil ??
charles
05-01-2002 06:32:29
 Re: Re: Re: fuel in oil HELP in reply to charles, 04-30-2002 17:29:15
thats what i feel must be in the carb ..but i just dont see how that much fuel could make it all the way up to the intake without a starting problem.this is a gravity flow system so no pump.its got to be in the carb thanks all i will do a rebuild
