Massey 135 headlights
Bill in TN
05-01-2002 04:38:17
Is there an easy way to remove the sealed beam from the rubber housing that holds the headlamp? Anyone know if the headlamp is available with the housing? Thanks, Bill in TN
Jeff in TN
05-03-2002 14:49:05
 Re: Massey 135 headlights in reply to Bill in TN, 05-01-2002 04:38:17
Bill,
The ones I had were dry-rotted and fell apart when I tried to remove them. I bought new rubber rings from the M-F dealer..less than 10 bucks each as I recall.
Big Dean
05-01-2002 14:43:34
The way I always replace the seal beam in them was to pop the rubber out of the light put the new seal beam in the rubber be sure the tabs are in the notches rub some hand cleaner on the rubber where it slips in the light to lubricate it so it will slip in easier. It always work for me I don't know how many I have put in that way. The last I knew you could still buy those lights at a dealer.
